96 Runner spring sag
I have a question. I picked up this 96 4runner awhile ago. Replaced the front with fabtech coilovers 2.5" and trailmaster struts. I adjusted the fabtech up to see if i could even it up and it still sags. The springs in the back are skyjacker. The back ends sags maybe a inch or two. When i examined the back springs the left one was off and was not inserted into the top. I had to use a bar to move it back in place. Are there spacers you can use on the top of the spring to lift it? I was reading the other posts about downey springs and a lot of people use them. New springs or can i use spacers? I don't know how old the springs on the back are. I am also waiting for 7100 bilsteins shocks to come for the rear so i would like to work on the springs when i install them. If you look at my avatar ( picture ) you can see what i mean. Help me out.
Thanks
Thanks
this might fix your problem...
https://www.yotatech.com/forums/f11/...runner-134494/
I'm selling them and used them for less than a year. They were from a revtek 3" kit. I measured them and found they are only 2" spacers. Not sure why they did that. They would put your rear level if not a tad over your front
06-01-2021 02:51 PM
Vargntucson
07-04-2015 01:15 PM
