96 runner with sagging rear coils
well i have a 96, so i might try to get a brand new set for free. i think they would be better than what i have on there now, and i wouldnt be spending any money either
If it's free, I say go for it.....just because it didn't work for me doesn't mean you won't like them. I was just sharing what happened when I did mine. If they sag you can also use the helper airbags to level off the rear.
well i just went to the dealership to see about the recall on my springs but i guess the previous owner had it done right before they sold it. oh well
#28
They should replace them for sure, not that it is worth anything but if cheverolet ever replaces anything for warranty they guarentee it for life. Also for reference I have a 99' SR5 and I just replaced the springs because they were sagging so if you buy springs go with a new set. I put Downey 2" in the rear and 4runner barely sits higher in the rear. However they cost about $200. The stock shocks fit fine but they were not dampened enough for the higher spring rate. The back end became a pogo stick, so if you have worn shocks you will probably be buying those as well.
#29
hmm i didint know there was a recall ill have to swing buy the dealership and ask
#30
......unless maybe you can find a sympathetic dealership to fight on your behalf.
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
