95 Tacoma throttle problem
Old 12-21-2004 | 07:09 PM
pat2724's Avatar
2.4 L automatic when the truck sits or is cold I hit accelerator and the truck takes right off, when warmed up the peddle feels stuck, I have to push it harder than usual to get it going. I sprayed wd 40 on th throttle body and it works for a couple days then it feels hung up again.It does not happen ll the time.
Any ideas??
thanks
Old 12-21-2004 | 08:35 PM
Nic's Avatar
Nic
Sounds like the throttle body. I assume when you said sprayed WD-40 on it, you were talking about the (cable) outside of the throttle body. If that is the case, try cleaning the throttle body on the inside and see if that helps it.
http://www.4x4wire.com/toyota/mainte...throttle_body/
Old 12-21-2004 | 08:36 PM
jtm994's Avatar
try cleanin out the throttle body
Old 12-22-2004 | 03:38 AM
pat2724's Avatar
How do you clean it out? I never did that before.
Thanks
Old 12-22-2004 | 05:27 AM
Nic's Avatar
Nic
Check out the link in my post. It has instructions.
Old 12-22-2004 | 06:42 AM
jtm994's Avatar
it really easy all u need is a cloth some carb cleaner and a old toothbruth...it takes about 20 mins. just get all of the black out of it
Old 12-22-2004 | 07:36 PM
pat2724's Avatar
Thanks guys I cleaned it and it works better.
smthwsn357
05-01-2024 08:28 AM
kazuya2416
04-05-2024 03:17 AM
Alex Bessinger
08-31-2015 10:17 AM
Seattle_Sign_Guy
07-12-2015 01:38 PM
Poncho0206
07-10-2015 07:21 PM
