94m 4 Runner OBD II code reader needed
Toyota fans:
Which code reader do I need for the 3.0 V6 94 model engine?
Who has one at the best rpice/quality match?
I know how to do it with the T1-E-1 jumper wire. Do i really need one?
just use the jumper wire and count the blinks as per the haynes manual. You don't need a code reader for this truck.
MadCityRich
2002 4Runner
OBDII 96 +
A typical OBDII scanner will not work with an OBDI.
The only way to get the codes without a high dollar scan tool is to jumper the diagnostic box under the hood.
So, OP only needs to invest in a paperclip
DuckFan
11
06-19-2002 12:56 AM
