88 p/u running rough
i have an 88 p/u that is running rough, idle is very low, will stall at stops if i don't step on the gas. lots of black smoke. a couple of times it has run on after shutting off. I can smell gas often. i have checked the vacuum lines with starting fluid, no change. i changed plugs dist cap & rotor, air filter, no change. engine has 212,000 and have do major work on it. any ideas, i am open to suggestions.
thanx,i'll checkout the timing, the timing chain is original, so that could be part of the problem, mine has a carb, a mechanic told me the carb was bad, but he had no explanation, i think he just wanted to sell me a carb
Ya deffinetly do your timing chain. Get a steel rail off of ebay, i got mine for $52 with shipping.
Also I have 2 carbs sitting in my garage right now, one from a running 22R and another older one but I'll sell ya both for $100.
09-04-2015 09:27 AM
v_man
07-23-2015 04:01 PM
