'86 Turbo install..
It might be easier to swap in a stock22re turbo engine. If you do it that way, you'd just need the engine and ecu. If you put a turbo in the stock 22re, then you will need to get the turbo exhaust manifold, bigger injecters, 22ret ecu, drill a couple of holes for the oil lines...There's probably some other things, but I can't think right now. check out Jeff Moskovitz's site for what he's done to his 22ret engine. Jeff's '86 turbo site
Salue
Salue
TheBFA
02-15-2020 06:55 AM
CPD4runner
9
11-05-2017 06:01 AM
voiddweller
53
02-01-2016 05:46 AM
