86 pu suggestions
Old 09-02-2005 | 09:06 AM
86SR522REEFI's Avatar
86 pu suggestions
I have a 1986 pickup 5spd 2wd in near mint (good for a 20 year old truck) condition with 69k miles on the original 22re i have a 3" body lift with Liberator A/Ts 235 75 15 with american racing wheels should i put a solid axle up front and lift it again and put some 33s on or should I buy a cheap ride w/ 4wd and mod that ill post pics soon
thanks
Old 09-02-2005 | 10:03 AM
Flamedx4's Avatar
The front frame isn't beefy enough to make it worth putting a drive axle up there, I don't think.
Old 09-02-2005 | 08:22 PM
kyle_22r's Avatar
actually, with the exception of the transmission(you need to do a tranny/crossmember swap to convert to 4x4) it's supposedly easier to convert a 2wd truck to 4 wheel drive than an IFS 4x4 to a straight axle 4x4. the reason is the frame on a 2wd truck has about the same amount of arch in the front as a straight axle pickup, which leaves more clearance for steering components.
the frames are pretty much the same strength-wise.
primordialbeast117
12-19-2015 01:23 PM
Ditch Doc
10-27-2015 04:20 PM
Iceman4193
10-16-2015 11:50 AM
zombie_barbarossa
10-02-2015 11:54 PM
the_supernerd
10-01-2015 10:20 PM
