86-95 IFS Balljoint Spacer Group Buy
#261
Originally Posted by s_wall98
So is there anyone running these spacers with 33x12.50s (stock rims) on a 2nd gen runner?
#262
It's looking like the issue is relating to where that tire bulge lies. That can change from tire to tire and would explain why it's hard to pin down what is causing the problem. What brand/size is that tire?
You can take a little meat of the end of the arm too in order to help clearance.
As for tire fitment, you can put a 33X12.5 on a stock rim, but it's not recommened. It will wear out the middle of the tire quick if I understand correctly. It's one of those "you shouldn't do's" that we wheelers might do if say were aren't running on the street a lot or just plain don't care if the tires wear out quick. (like running a welded diff)
Frank
Frank
#264
Originally Posted by KevyWevy
so 3 and 3/4" will work? hmmmm me gotsta get some wheels, seeing how the rubbing only seems to be happening on stock steel wheels.
Frank
#266
Originally Posted by myredyota
So, those of us with stock rims, are we hosed? I don't want new rims, and I don't want to buy 4 spacers. I have the stock al. rims with 31x10.5 :pat:
The best I can tell, this problem seems to follow the tires as some work and some don't.
I would love to compile a list of those with problems and those without.
Frank
#267
Well, since I am about 3/4 the way done with one side, 14 hour days suck, I guess I am about to find out! How much space is enough between the upper arm and the tire? Who sells spacers if I do need them? Sorry if I was panicking---it has been a rough week.
#268
Frank
#269
I am smiling! I was worried about nothing! I got the driver's side done tonight. No rubbing at all! Stock aluminum rims with 31x10.50 BFG AT/KO. It was actually pretty easy. It isn't a great picture but here it is!
Let's hope I still have the space after I get it aligned.
#271
very nice!!!! i just ended going and buying some black steel wheels yesturday! i love the new backspacing! 3 3/4" look great with my fender flares! i got my cruiser coils on last night too!!!! hahahaha its cool how much is raked right now. too bad im at work right now. i wanna put my balljoint spacers in!!! i guess that will have to wait till tonight when i get off work.
#273
So this might be a little off subject but it does pertain to the spacers so I'm gonna throw it in here. I've got my spacers and cruiser coils are on the way. I plan on eventually putting some 33x 12.50s on (with the help of a BL I think) which means getting new rims (still on stock with 31s right now).
I was needing some help with some decision making: What size rims should I go with 15x8, 15x10 and any CHEAP suggestions? How crazy would my runner look if I went ahead and installed the cruiser coils (short side) and spacers, sticking with the 31s until winter?
Thanks
-Shawn
Thanks
-Shawn
#274
well i just went to Les Schwab, and saw that they had the rock crawler type steel wheels for $40 each so i got those. stupid mounting and balancing!!!!! *shakes his fist*
these are pretty much what they look like.
i just went with 15x8's those should work perfectly fine. i'm running my 31x10.5's on them right now and they'll work perfectly fine with 33x12.5's thats what im planning on doing, hopefully by the end of summer. i still don't know if i'll need a body lift, we'll see once i ge my bj spacers on.
as for the coils, i just bought a set of coils, short and long side. there was about a half inch difference between the two. there really isn't any noticable difference in height, from side to side. if you measure, yes there is a difference but barely. (i'll just put all my tools on that side!) once i get my bj spacers on i'll be making a thread with lots of pics and a few numbers, so don't worry. (forgot to take before measurments and pics :pat: i guess i was just too excited to get them in!)
oh and feel free to messege me if you have any questions!
#276
Basically I posted in the classified section of any off-road forum I could find. Before that I called around to some junkyards, but didn't have any luck that way. Try www.ih8mud.com, I think that's where I ended up finding mine. I'm not at home now, but tomorrow I'll check my favorites and let you know of any other forums.
#279
is your comp on the fritz or something? why do you keep posting that?
I must be on the fritz! I tried posting it last night, this morning I couldn't find it, so I tried it again...when I hit submit, it wouldn't go, so after after lunch, I tried again! We are painting our basement, must be the fumes....sorry!
coffey50
07-28-2015 10:55 AM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
07-21-2015 07:54 PM
FS[NorAtl]: set of 4 ball joints. any torsion bar ifs 4wd
akaphilly
07-09-2015 02:27 PM
