5vzfe hard start after fueling
Old 01-20-2016 | 11:45 PM
wyoming9's Avatar
Red face
Put a fuel pressure gauge on and check pressure.
The fact your not getting more codes makes me wonder if the ECM got wet.
I went through 3 before I moved mine parallel to the heater box and off the door post
I can`t see what filling the truck up with gas has to do with the no start issue as I only fill me tank when I get gas.
Real time data sounds like a good idea
You are having swap issues your still working through after 6 months
Old 01-21-2016 | 08:14 PM
scott90's Avatar
I'm going to try a new computer this weekend and see if it helps at all. What still gets me is shutting the truck off and back on temp fixes the hesitation. Also going to test fuel pressure this weekend as well. Wish there was a easier way instead of plumping into the banjo fitting
Old 01-22-2016 | 02:55 PM
scott90's Avatar
Checked codes again. Only one was cam position sensor which I replaced already. Timing is good, timing belt is good and no damage to cam gears whatsoever.
Old 01-24-2016 | 12:24 AM
wyoming9's Avatar
Red face
You have to remember it is the complete Cam Sensor Circuit !! Might be a corroded plug open circuit in the wiring
Thing is the ECM if it does not see the cam sensor signal It will shut off the fuel which does not seem to be occurring from your posts
Old 01-24-2016 | 10:14 AM
  #25
scott90's Avatar
I'll try cleaning the connection and tracing wires, so if I unplug the sensor while it's running it should shut the fuel off?
Old 01-24-2016 | 10:28 AM
  #26
wyoming9's Avatar
Red face
When the ECM does not see a few of the signals from sensors the ones that give information that the engine is running.
It shuts off the fuel or should.
Old 01-24-2016 | 10:35 AM
  #27
scott90's Avatar
Ok because I've unplugged it while it was running and never really made that big of a difference. Hopefully have a new ecm Monday to try out and I'll take some sand paper to the pins in the connector to the cps
Mattluke1
10-31-2015 07:16 AM
Brendan
10-30-2015 10:08 AM
Fatlipnatties
10-20-2015 05:18 AM
AFewScrewsLoose
10-09-2015 06:53 PM
scott90
10-08-2015 03:01 PM
Quick Reply: 5vzfe hard start after fueling
