4WD Light Blinking
Old 09-13-2006 | 09:19 PM
FTaco's Avatar
4WD Light Blinking
Hi Y'All,
I've got a problem with my 4WD that I'm hoping some of you may be able to help me with. The 4WD light (on the push button actuated system) blinks when I put it on, and the 4WD isn't engaging. Any help figuring this out is appreciated? Thanks in advance,
Doug
Old 09-13-2006 | 09:26 PM
YotaFun's Avatar
Are you just standing still or are you rolling?
And does it eventually engage or is it just constantlly stay flashing?
Old 09-13-2006 | 09:41 PM
FTaco's Avatar
It always blinks (when the button is engaged) and it blinks regardless of whether I'm moving or parked. The 4WD never engages.
Old 09-13-2006 | 10:08 PM
seanz0rz's Avatar
Guest
would help lots if you gave us specifics on your vehicle.
check front diff for loose vacume lines.
Old 09-13-2006 | 11:00 PM
FTaco's Avatar
I'll check the vacuum hoses tomorrow. I think based on the latest posts that I will be able to figure out the routing. As for the specifics, '95 Taco V6 SR5. It has about 260K km. I've never had any issues wrt to the 4WD yet. All of the posts related to vacuum hose leaks never pointed out a blinking light, so I thought maybe that was a tell tale sign of sorts (i.e. electrical maybe). Anyhow, there it is.
Old 09-14-2006 | 08:47 PM
FTaco's Avatar
bumpity
Old 09-15-2006 | 09:03 PM
Sparman's Avatar
I have a similar problem with my 02 4R with the push button engage on t-case lever. It is intermittent and very frustrating. Occasionally if I choose to engage 4hi - it'll blink and never actually engage. Then the entire system becomes unresponsive, and it may continue blinking for days. Out of the blue, it'll engage and work as intended. It's been extremely frustrating, I've posted about it here but it's a phantom and only affects 01-02 years - I believe. Some have pointed to actuator solenoids in the t-case, but as far as I know, nothing definitive has been blamed.
What I've come to find out about your year, however, is that it is most likely due to a faulty vacuum line. I'd start there.
Old 09-15-2006 | 10:43 PM
FTaco's Avatar
Thanks Sparman. I'll have more time to work on it tomorrow and I'll update when I know more.
Old 01-15-2007 | 02:28 PM
4runner02's Avatar
FTaco,
Have you gotten your 4wd system to work yet?
mskalmus
05-28-2017 08:51 AM
adammtb
07-27-2015 12:57 PM
Athansinis
07-27-2015 09:38 AM
ripp96
07-25-2015 03:32 PM
TokyoD23
07-12-2015 07:01 AM
