4WD indicator light not working
HI,
4x4 is working when I push the lock, but the indicator (located on the right side, just below the fuel gauge) will not work. Now, I checked fuses, they are ok, I checked sensor (it may be called different but I don’t know proper name for it) which is on gear box connected with two wires, this sensor is ok. Also I checked bulb on dashboard and it is OK. What to do. Should I check something else.
Igor
Igor
Are you sure the 4x4 is working? How did you test it?
I had the same issue. Here is my thread.
https://www.yotatech.com/forums/f2/actuator-4wd-my-4wd-wont-engage-91288/
Aleeex_u
06-05-2016 06:52 PM
