4wd indicator light not showing
I own a 99 4runner SR5. The four wheel drive works as far as I can tell due to the jerking action when I am turning in the vehicle. However, my 4 wd indicator light on the dash is not lighting up when it is engaged...could this be a fuse...If so which one would it be, I tried to figure it out.
Thanks!
Thanks!
is that easily replaceable? I mean I am sure you would have to take off the dash and everything...if that is not to difficult it would be worthwhile to replace it for sure if it is a bulb.
thanks.
thanks.
I just came across the same issue this morning with my 91 4runner. Mine jerks like its in 4wd but don't believe it...I tested mine on a hill and just my back tires spun. So it might not be engaging like mine...test it out before you think its just a light. I don't have a clue as to what mine is. It defeats the purpose of owning a 4wd that won't go into 4wd.
I can too...seems like it jumps forward when i lock it into 4 wheel low and i know what you're saying about the steering in 4 wheel drive....slightly hard and almost lurches...im in the middle of jacking mine up to see if mine fully engages or not. good luck!
just found out my problem....there is a 1 way check valve by the 2 vsv's on the passenger side fender...mine wasn't letting any vacuum thru. the check valve is hooked to a vacuum line that hooks to the passenger fender...and outside the fender there is more vacuum hose that goes to a canister under the fender by the front. should be two vacuum lines hooked to it. i remember what 4hummer said about pulling each line off individually and said one sucks and one blows...go figure! hehe...anyways i was thinking...no vacuum there so maybe ill go up the vacuum system. i pulled that check valve off with the vacuum line attached that attaches to the intake....no vacuum...pulled the check valve out......SHHHHHHHHHH....i was like....HOT DAMN! cleaned the check valve out by blowing some high quality H2O thru it...only thing i had on hand...and hooked it up....vacuum! got in...put it in 4wd...light on! came home...pulled on hill...put it in 4 wheel lo...no spin! thats the way i like to see it....so thanks 4hummer!
glad you found the problem. i know on my 94, theres a connector by the transfer case, and when i was having the same problem, i found that unhooked and walla! my indicator works once again. same thing solved my backup lights not working, little connector up by the transmission.
i'll keep that in mind too if mine ever goes out....which connector is this? I kinda glanced over mine and saw 2 or 3 things connected to mine but didn't look at it long...hey just curious...are you in charleston wv? sorry for being off subject but i clicked on your link and it said something about baseball in wv.
George
yeh i figured this would take a while but i was persistent as hell and having a 4wd and knowing it doesn't work....nah i can't be havin that! northeast florida huh? what part? maybe u could show me some place to use this 4 wheel drive because im from west virginia and i haven't saw any places even compare to up there so far!
Originally Posted by george16
I lived in Jacksonville too. I'm in the Navy and will be going back on deployment on the 27th. I haven't found any good places to wheel. Let me know if you find any.
im not in charleston wv, i did play baseball there in 2003 for the alleycats, Low A league with toronto, but i believe they're affiliated with milwaukee now and we have moved to lansing michigan.
haha....yeh kinda set myself up for that dumb question. I used to live in Charleston...then moved to a small town named buffalo wv. now jacksonville florida! i miss the country there to go 4wheeling at anytime but the job market sucks!
Alright, glad you figured it out! Can you help me? Where exactly are those vaccuum hoses located on a 994runner? Anyone know?
I tested the 4 wheel drive this weekend in the snow, and it definitely works...I will spare you the detailed explanation, but I know it works. The indicator light still is not on though...in this case I suppose it must just be the bulb if the 4wd works right? Or could it have to do something with the hose issues?
thanks!
thanks!
