4Runner Suspension Help/Ideas
Hello and Happy New Year.
I was referred to this forum from one of the other 4Runner forums and I hope I can find some advice....
I have a 2000 4Runner, 4x4, SR5 with sport pkg. I have only added 4 HD Bilsteins - otherwise the truck is stock. I recently removed the Borla cat back system because (yes) it rotted and cracked at the muffler. That's another story.
So my questions are:
I want to improve the off-road ride - right now it's not stiff enough. I rode in my buddy's stock wrangler the other day and it's unstoppable. With my truck I would have to slow down or risk bouncing and bottoming out.
I have stock 265/70/16 tires which need replacing now. I would not be opposed to getting a little more lift and adding some 285's in the process, but I don't want to go crazy adding brake line extensions, etc.
So, what do people recommend? Obviously it would be springs at the least, but what type/brand? The Bilsteins are about 5 years old, but I don't notice much difference compared to when they were new. Regardless, I can replace those too if warranted. How do you guys deal with the speedo being off with the bigger tires? Just ignore it?
Finally, since I reinstalled my stock exhaust and think it sounds whimpy - what are the recommendations here? Borla claims they can't make me a new one - How about a TRD? I have CA emissions.
Thanks.
Jeff
Thanks.
Jeff
Excellent. System 7 looks like exactly what I want. Question: on the truck shown with stcok wheels in the system 7 photos - are they 265 tires do you think? Maybe i will email them. the only worry I have is that I have stock running boards which I would like to keep. Any issues there?
Jeff
Jeff
From the FAQ on SS site
11. What size tires can I run? With System 1,4, 6 & 7: You can run 265/75/16 (32") tires on stock wheels or 285/75/16 (33") tires on stock wheels. With the 285 you may to trim a bit of the plastic liner in the rear of the front wheel wells. Nothing major and no big deal. With System 3: 265/75/16 (32") tires on stock wheels is what we would recommend.
It looks like that worked, as I am interested in the system 7 kit from Sonoran.
I just installed the system 7 two months ago and I am very pleased. I am quite picky it when it comes to driving dynamics because I expect my truck to do well offroad and I expect it to be a comfortable road tripper and daily driver. The ride is better than stock...a little stiffer initially but it no longer bottoms-out on medium and large bumps and the ride is considerably better when loaded. I haven't been able to get the caster (alignment) adjustment in spec, which is the only negative aspect I can think of. Some claim there should be enough adjustment.
If you choose to run 285s, be aware that some people have rubbing issues on the upper control arms and on the frame/inner wheel well without a 1" body lift. I am running 265/75R16 BFG ATs and have no issues. Here is a pic:
Good luck with your decision.
That's perfect for what I am looking for.
How far out is the alignment? I'll get that done after the install, when I get the tires. I'm gonna opt for 265/75/16.
I'll search the forums some, but any suggestions on the exhaust?
Jeff
Jeff
Did you install that yourself? Any advice on that? I'm pretty good mechanically and have probably all the tools - air, etc. I may need a better spring compressor since the one I have is pretty cheap. Any recommendations on a good one ?
J
J
I've been using them for a while and they work fine (although they went up $10 this year, mine were $39).
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
I did it with the help of a friend. If I could do it all over again, I would take the front coil/strut assembly to a shop and let them install the lift coil on the strut. The spring compressors are scary, and in our case, Tokico supplied the wrong nut for the top of the strut assembly and the unit blew apart as we were backing off the spring compressors. Luckily no one got hurt. I posted more details about this incident about 2 months ago.
Other than that, everything else was very straight forward and I would not hesitate to do any of it myself.
Ken
Ken
Thanks!
Ok, so I talked to Steve at Sonoran, and ordered my kit. Nice guy. Since I do most of my off-roading on soft sandy trails, we changed the System 7 a bit and went with the better TRD/Tokico Blue shock up front. The rear will be the green shock included in the kit. He seemed to think my HD Bilstiens I have now would be too stiff with the new springs. So thanks for the input here!
My tires are going to be the new Bridgestone Dueler A/T Revo in 265/75/16. Getting a quote on those this afternoon.
Next is a stainless cat back exhaust, and I am soliciting opinions on another thread for that.
Jeff
Jeff
06-01-2021 02:51 PM
09-04-2015 10:27 AM
Vargntucson
07-04-2015 01:15 PM
