4Runner Sidemarker lamp/bulb replacement?
I need to replace a bulb on my wifes 99 4Runner. I did an ulta-quick inspection, looks like the sidemarker assembly has to come out in order to change the bulb. Single screw up top is visible..but I know toyota, there has to be more
Anyone give me the locations and/or the removal procedure before I jump in there? Don't have a lot of time in order to turn wrenches anymore so it would be nice to know the battle plan beforehand.
Thanks!
James
Thanks!
James
you should only have to remove the screw on top and then pull it straight out towards the front of the car. i think there is a little expanding plug thingy that holds it in. you might have to pull kind of hard, at least on mine you do.
Vargntucson
07-04-2015 01:15 PM
4runner, 99, assembly, bulb, change, forerunner, lamps, light, marker, replace, replacement, side, toyota, toyota4runnerbulb, turn
