4runner passanger windows issue
I have a '95 4Runner, V6, limited.
I replaced the positive side of battery terminal without issue, but after doing this the passanger windows will not roll down from the master control on drivers side OR from their own individual buttons. Bottom line is that drivers side window is fine, sunroof is fine, back window works WITH THE KEY, but not from inside. All fuses have been checked and are fine, even the hidden one that has to do with power windows. I am lost here, no clue.
Thanks to anyone who responds,
Nathan
Nathan
Originally Posted by gwhayduke
Check the child-proof safety switch in the master panel. I'll bet a dollar to a doughnut that it's engaged. :pat:
where is this childproof safety switch that you speak of?
Nathan
Nathan
I'm also having window problems
location of window fuse
Originally Posted by WIZARDOFODDZ
May I ask where this so called hidden fuse is located?
Sure, that fuse (on a 95 3.0 V6 limited) is toward the firewall right next to the other fuses on the drivers side kick panel. You have to take the panel off with a little hand-turn screw and then it is hiding way back there, it is one of those square fuses and it controls all windows and door locks. Hope that helps.
06-01-2021 02:51 PM
MMA_Alex
25
04-18-2017 06:07 AM
Jnkml
07-06-2015 02:20 PM
