4 Runner Tacho wiring diagram
Can anybody help me with the colour coding for the tacho wiring onto the injector pump i.e. what colour wires from the loom connect onto the two blue wires on the diesel injector pump (2L-TII). The idiotic owner before me cut the wiring loom.....
Here , I hope this helps
Toyota
4-Runner
1994-1995
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Start:
BLACK
IGNITION SWITCH HARNESS
Ignition #1:
BLACK/RED
Ignition #2:
BLACK/YELLOW
Ignition #3:
Accessory:
BLUE/RED
Brake Light:
GREEN/WHITE
(+) AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
BLACK
AT IGNITER OR DIAGNOSTIC PLUG *
Parking Lights:
GREEN
(+) AT WHITE 8 PIN CONNECTOR@FUSEBOX
Headlights:
RED/WHITE
(-) AT HEADLIGHT SWITCH *
OEM Alarm Disarm:
OEM Alarm Arm:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Igniter Located On Driver Firewall, Diagnostic Plug Located On Passenger Side Of Engine Compartment On Fuse/Relay Box. BLACK Tach Wire Also Found At Pin #20 In A White 20 Pin Connector In Passenger Kick Panel.
Toyota
4-Runner
1994-1995
Function
Vehicle Color
Start:
BLACK
Ignition #1:
BLACK/RED
Ignition #2:
BLACK/YELLOW
Ignition #3:
Accessory:
BLUE/RED
Brake Light:
GREEN/WHITE
Tach Signal:
BLACK
Parking Lights:
GREEN
Headlights:
RED/WHITE
OEM Alarm Disarm:
OEM Alarm Arm:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
Breezy, I just installed a keyless entry system (Valet) and have a question for you.
Will the parking lights only blink if I add a relay?
I didn't realize it was a positive connection unitil it didn't work.
most of the time the alarm will have the relay built in, if not you do need to add one . The parking light wire is right below the fuse box on the drivers side, very easy to get too.
Thanks
Thanks Greg A,
My 4Runner is 1st Generation Japan version, 2L2-T motor..
voiddweller
19
05-02-2016 09:10 PM
91toybeater
12-27-2015 07:46 PM
TheManOutside
06-18-2015 03:32 PM
