4 runner lift install
Looking to put a toytec full 3in kit (OME) on a 2000 4 runner. I'm getting the diff drop spacer as well, but is there anything else that I will need? Any special tools or other things that you became aware of while doing the install...such as extended brake lines, etc.
Thanks
Thanks
Yes, to the poly steering rack bushing kit. i also did an adjustable pan hard from Sonoran steel, as my driveshaft was getting pulled to the passenger side. Im also considering the rear brake load sensor bracket, also from Sonoran steel. If youre going to do 285's, spacers may be needed if you have OEM wheels.
voiddweller
19
05-02-2016 10:10 PM
88Toy
7
06-17-2015 10:40 AM
dandownunder
06-10-2002 07:18 AM
