3VZE timing belt.. which idlers did you replace ?
Old 11-28-2005 | 02:53 PM
nrgetic99's Avatar
Ater reading horror stories about water pump failure, I am going to replace my noisy pump this weekend.
I picked up :
* Pump
* Black sealer
* Timing belt
* No 2 idler pulley (big one)
* Tensioner
As I get a trade account I got all the above for $240 which ain't half bad
Do I really need the No 1 Tensioner ???
I can pick it up and return it if I don't use it but I cannot recall anone here saying they replaced it....
What did you do when you replaced your belt ??
Thanks
David
Old 11-28-2005 | 03:01 PM
ChickenLover's Avatar
David
I sure wish I would have. Oddly enough, all 3 of my idlers started to show signs of wear at the same time (#1 and #2 on the timing belt and the one at the very bottom of the accessory belts that acts as a tensioner for the AC).
During my top end rebuild my idlers had no play in them and made no noise when spun, so I did not replace them. Now (10 months later) all of them have considerable play and #1 is actually squealing at idle. If I were you, I'd replace it just to be on the safe side.
Old 11-28-2005 | 03:29 PM
eric-the-red's Avatar
I only replaced the #2 pulley when I did the pump on my 93 4Runner, drove it for 2 years after that with no problems from the other idler.
Old 11-28-2005 | 03:39 PM
vegaskurt's Avatar
I did both pulleys on my 3.4 when I did the timing belt and water pump. Both did have a slight grind to them when I spun them by hand. Im sure they were years from failing but better safe than sorry. Since you have it apart you may just want to do it.
zd92655
03-06-2022 01:58 PM
voiddweller
19
05-02-2016 10:10 PM
Ichneumon
09-27-2015 05:21 PM
newzingo
06-24-2015 02:50 PM
infinityisfive
06-16-2015 07:51 PM
