3rd Gen Lifted Flex Pics! Lots of them!
#41
Originally posted by sschaefer3
Marrying your relatives is a big plus as well !!!
im gonna make you squeal like a pig son :pig:
#42
The King has tried the Revtek top out with the RaceRunners and the results are top secret.
let me know asap...
#44
I live in Tempe, which is in the Metro Phoenix area.
Originally posted by ravencr
I need to research the Arizona, California, and Colorado states much more before I make such a large move. I love California, Utah, and Colorado, but deciding where to live and work is a totally different story than vacationing.
#45
Well, I'm real far away from retirement, but I want to live somewhere that I love, not just like for the most part with one thing that sucks. I've got to do some more traveling out there to really find out what we should do.
Chris
Chris
#46
Originally posted by RTdawgs
ive been thinkin about this. its similar to the revtek 2 spacer design, but with the added flex of the SAW shock and ATS arm.
let me know asap...
let me know asap...
#47
Boy we're so far off track, it's not even funny. But, will your MC09 work with an automatic tranny, because it says just manual on their site from what I can see. I'd love to get at least the 4.7 gears, and possibly the dual case setup, but their site is a tad unclear of which works with the autos and 4runners, because it actually says it works on Tacomas.
Chris
Chris
See if you can move your rear drive shaft mount back 8.5". Obviously it can't go past the rear crossmember or gas tank.
So as a rule of thumb, it's pretty much an manual tranny thing. But check it out, maybe it will fit, see if you have 8.5" between where it ends now and the rear crossmember.
#48
Does it matter that I've got a 1997, not a 2001-02? I'll check to see if I've got the 8.5" of room.
Chris
P.S. I can at least get the 4.7:1 crawl ratio for it though, can't I?
Chris
#51
Ok, Steve, you won't beleive what the popping sound was. When I installed my lift, I had disconnected the driver's side bolt on the panhard bar to make it a tad easier to flex the suspension out to get the springs in and out.
Once I resintalled everything I had installed the bolt reverse of the way it was supposed to, because it was sort of a pain the butt to get it back in. Well, today after trying to figure out what the hell was going on with this noise, after tightening the driver's side and the new bolt you supplied for the panhard drop bracket, I decided that something was still screwed up.
So, figuring, but highly doubting it could have been because I reversed the bolt, I removed the bolt to find that the part closest to the head of the bolt was slightly larger in diameter than the rest of the bolt. So, after reinstalling it the correct way, to my surprise, the popping was gone.
I couldn't beleive that slight amount of flange on that bolt made that kind of difference, but now everyone knows that bolt should only be installed one way, the right way!
Chris
Chris
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
tpd143
07-07-2015 09:06 AM
