315s on 4.10s?
Old 12-14-2007 | 04:49 PM
CASTAIC 4RUNNER's Avatar
if you have a 4x4 NO e-locker you probably dont have 4.10's you have 3.90's...ADH8796, you told me you have 3.90's did you regear to 4.10s
Old 12-14-2007 | 07:55 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
I had a 4.30 non-e-locked ... that is until i swapped in a 4.30 e-locker 3rd
Old 12-14-2007 | 10:08 PM
BajaRunner's Avatar
Big difference for me from 265 to 285. Another good difference between alloys to steelies. No difference in acceleration from 285 steelies to 315 steelies. Only change I noticed was braking distance and decreased gas mileage and a smaller penis.
Old 12-14-2007 | 11:00 PM
dropzone's Avatar
Fossilized
Originally Posted by AxleIke
Anyone whining about power on a 3.4 has either NEVER driven a 22R or RE or forgotten what it was like. Even regeared, 95 horse gets you nowhere fast. But it does get you there.
that is so true...
Old 12-15-2007 | 12:04 AM
  #25
sportlocked's Avatar
run em, make sure they fit, trim where needed and regear with precision gears since thats what I have.
Old 12-15-2007 | 12:43 AM
  #26
4rx's Avatar
4rx
Let me just throw in my 2 cents.
exactly, it still get me from point A to B.
wow i didnt know theres so many of 3rd gen 4Runner on 315s. im still new to yotatech!
Old 12-15-2007 | 07:35 AM
  #27
MillerPKA's Avatar
yeah i'm surprised, a few of you are coming out of the woodwork to post up...i like it
Old 12-16-2007 | 05:10 PM
  #28
Nate08's Avatar
Climbed under tonight. Had a friend watch my tire. Jacked up one side and started. Rotated the driveshaft 41 to the tire 20. I guess my door panel is right, 4.10's. So...I supposed I'm clear to run 285's.
Old 12-17-2007 | 01:27 PM
  #29
ninjarunner's Avatar
Do it. I counted mine and the door panel was wrong. I got 4.10's and love the 315's... so 285 is no problem.
Old 12-18-2007 | 04:34 AM
  #30
Nate08's Avatar
Sweet. When I do upgrade to 4.56's in the rear, should I also upgrade to 4.56's up front?
Old 12-18-2007 | 05:42 AM
  #31
MillerPKA's Avatar
yes no reason in keeping your rig out of synch
Old 12-18-2007 | 06:03 AM
  #32
Nate08's Avatar
What would happen if I had 4.56's in the back, 4.10's up front, and put it in 4WD? Anything tear apart?
Old 12-18-2007 | 06:26 AM
  #33
Greg_Canada's Avatar
unless you were in deep snow you'd def f- something up.
you can be off a % or 2, but not that much.
(ex 5.13's and 5.29's are ok)
Old 12-18-2007 | 07:57 AM
  #34
AxleIke's Avatar
Do you have a center differential?
If not, you will do one or more of the following.
1. Completely strip the gearing in your transfer case- WAY more expensive than a front re-gear.
2. Completely strip either the front or rear diff gears- Same cost as a regear.
3. Snap ujoints, axles, etc.- possibly cheaper than regear, unless you are completely stranded out somewhere, and have to get a tow.
I understand the need to do things on a budget. I'm sorry, but you simply CANNOT run different gear ratios. Suck it up and get both done, or leave both alone.
Old 12-18-2007 | 07:59 AM
  #35
Nate08's Avatar
Just asking.
Old 12-18-2007 | 08:05 AM
  #36
Rock Slide's Avatar
Yes, x1000 with what others have said...be sure to match both ft and rear w/ the same ratio.
Old 12-18-2007 | 09:05 AM
  #37
Just asking.
if you cant get the front done, just dont even bother putting it in 4wd.
Neliconcept did that, except he bought an already setup 4.56 front diff and had to get the rear done, he just opted for a 4.56 arb from inchworm.
even though i do not like 4wparts, they do setup gears. but id look for a more professional shop around town that would be more reliable and has a better knowledge of r&p setups
I8URSVT
10-05-2015 08:23 PM
SharpStick
08-29-2015 01:59 PM
mtb_taco
08-20-2015 01:16 PM
boogiewoogie
08-17-2015 01:47 PM
