3.4 v6 5VZ-FE Thermostat
Does anyone knows what is the Thermostat temperature for the OEM Tacoma 3.4 v6?
I'm trying to adopt an electric fan and need to know what sensor should I get based on thermostat temperature.
Per FSM (Factory Service Manual):
"Valve opening temperature: 80-84°C (176-183°F)
Valve lift: At 95°C (203°F): 8 mm (0.31 in) or more
If the valve opening temperature and valve lift are not within specification, replace the thermostat."
