3.0L Engine "Drag"
3.0L Engine "Drag"
I have a 3.0L in my 4Runner that has started dragging a bit on acceleration. And has low torque/power..
I was getting a code for the igniter which I resolved after replacing everything on the ignition side - igniter, coil, cap/rotor, plugs & wires. The drag effect is still there after changing out the ignition components. however I cured the complaint from the computer (engine light would come on at 65 or so MPH) with the resulting code for igniter problems. I've just had to do a timing belt/water pump job due to a the idler pully bearing going @ 161,000. While the timing belt/etc made the engine quiet, it didn't do anything for the drag.
I was thinking a vacuum leak, but have replaced the valve cover gaskets, PCV, etc. about a year ago.
Any chance this could be related to the EGR valve? Its a component that could cause some issues if it didn't close fully..
AmigoAZ -> now WA...
Originally Posted by callmej75
downside for the timing is low end loss of power
Originally Posted by green91runner
the yota technician said 'it will give you a lil more power on the low end' as he advanced my timing to 12-13.. although, this picked my truck right up, made it sound healthy again.
Seattle_Sign_Guy
07-12-2015 01:38 PM
