3.0 turbo 4runner on ebay
Originally Posted by DeathCougar
la, ah-di dah. Its still a crappy motor that cant really handle boost, has head gasket issues, no power, no torque, etc etc.
I own both a 3.0 4runner and a 22r modified P/U and there is no comparison to the torque between the two...I've driven many 22RE's and even those cant compare in the torque category...the 3.0 isnt any GREAT motor but its a hell of alot more reliable and will outlast any domestic motor
i really want to do that to my 3.0. Anyone have any suggestions on what turbo to use? I looked up the one that was used in the 3.0 on the ebay auction, and i found one for a really good price, but are there any others that are better? Also, what other parts do you need except for the turbo kit? Any/all help will be really appreciated.
#25
22r's had...timing chains. Which you really can't compare to, since you should replace a timing chain just the same as you replace a timing belt on the 3VZ...its called mantinence.
The 22re, while a nice engine, is slow, underpowered, and has no torque. My 90 and some change horsepower is pretty sad. New gearing helps it, but unless you've got it geared really low, you'll still have it revved up when everyone else is idling over the rocks.
