3.0 crank pulley
3.0 crank pulley
First of all I have been lurking on this board for some time now but now I have a question maybe someone could help us with.
My son has a 88 Toyota 4x4 truck that we have just finished a valve job on. While putting the engine back together we noticed that the damper pulley (harmonic ballancer) has seperated from the rubber. I was wondering if there was a place to buy aftermarket or used parts such as this. I have checked all the local salvage yards and have come up empty. The dealer cost is too high for us.
Thanks in advance
Thanks in advance
if you know the dimensions and stuff you can check out emachineshop.comCLICK HERE. You have to use their program to get it to the dimensions you want and then you send them the plans and they mill, laser cut, turret punch, etc... whatever you want it made out of... check it out!
Try searching Car-Part.com You definitely want to replace that soon cause it will cause the power steering pulley to sheer off. This is from experience. They are pretty expensive. If you can't find one let me know and I'll see if I can pull the one off my old engine and maybe work something out with you, I got it from a yard.
Blamalam
03-12-2022 08:34 AM
TJWilly
07-31-2015 03:05 PM
