2wd 7.5 vs IFS 7.5 fitment non-Taco
Will these gears swap? The reason why I ask is because I have a 7.5 4.56 Precision Gear with a limited slip and I would like to use it in the front. Is it possible? I mean just the guts not the carrier.
James
James
yep. however, the rear 7.5 uses a third member and the carrier bolts into the axle housing on the front like a dana axle, so you'd need to re-set the gears to swap them over.
James
TheBFA
02-15-2020 06:55 AM
dirk89
10-01-2015 05:15 PM
JookUpVandetti
09-30-2015 08:58 AM
Cycles
09-29-2015 06:37 AM
