2WD and 15" wheels upgrading brake size
I have a 3rd gen 2WD with stock 15" wheels. I want to upgrade my rotor to the larger rotor for the 16" wheels. Can I use this setup with the stock 15's or do I need to go to a 16" wheel to have the bigger rotor?
Edwin... I'm proud that you finally popped up and are asking for advice. Good luck with your truck and I can't wait to see your lift. I'll be back at work on Tues the 7th, you'll have to swing by shortly after that. Later!
06-01-2021 02:51 PM
09-04-2015 10:27 AM
