2nd Gen Suspension
I will be purchasing the Downey HD springs soon and have Downey's catalog which shows springs, BPV bracket, and longer brake line. I'm quessing the limiting straps shown in the picture from Central4WD don't come in the 1.5" Downey spring "kit".
Originally Posted by TRunner
That is correct. I am not sure why they show that. The kit from Central4WD is the same kit from Downey, just a bit cheaper.
#25
That is the first time I've ever seen that for those generation pickups. How well does it align after having those installed even though the lower control arms are not relocated? Anyone have a set of these on yet?
Michael
Michael
Originally Posted by elripster
For the front, you can get 1.5" lift spacers atSDORS This will preserve the ride quality and increase overall travel. Merely adjusting the torsion bars sacrifices down travel for more height, overall travel remains the same.
I would not recommend the HD bars for your front supension for a few reasons. First, they are totally unecessary for lift. The height is simiply an adjustment, you have to adjust the HD bars to your liking exactly the same way you'd adjust your stock bars. Second, lifting the vehicle by means of adjusting the t-bars causes the ride to become more harsh. Third, combining that harshness with that of the HD bars makes for one REALLY stiff ride. Many have said their trucks feel as if it no longer has suspension. Only those who regularly jump their trucks seem to like that set up.
Since my 4runner has leaf springs I can't help you with the rear lift.
Frank.
Frank.
#26
There is a hugh thread (26 pages) on 4x4Wire under IFS ball joint spacer. There is also a thread on Yotatech.
http://www.4x4wire.com/forums/showfl...=&fpart=1&vc=1
Pages 16 and up have pictures etc.
#27
Originally Posted by Robinhood150
I ran the original stock shocks for a while with the downey 1.5HDs. Now I'm running the stock length rancho 9000s (I think they might be an inch longer though).
When you went with the stock lenght rancho 9000s, did you extend the rear brake line? Also do you have the part # for the rancho's 9000s.
Thanks,
Chris
#28
Originally Posted by CMD93
Robinhood,
Thanks,
Chris
Thanks,
Chris
I don't know the part # because I bought them used. Rancho has a pretty good pdf the shows which shocks fit which trucks. www.gorancho.com
06-01-2021 01:51 PM
89fourrunner
02-17-2016 06:52 AM
FS[PacSouthWest]: Husky floor liners '90-95 4runner
rocket
01-21-2016 05:03 PM
vanion2
07-29-2015 06:17 PM
Steezy96yota
07-06-2015 10:00 AM
