2nd gen cclutch problems
2nd gen clutch problems
My 95 SR5 3.0 5sp has had 5 new clutches in 80K miles, and the current one is starting to chatter. I have had the dealer service mgr, the district service mgr, and various service reps drive with me to see if it is a question of how I ddrive (all my vehicles have had manual transmissions including my 72 240Z that I owned for 15 years). It was so baaad that on one visit to the dealer they couldn't even back the truck oout of the stall! I currently have a dealer installed aftermarket HD clutch installed and it too is failing. Warrenty is gone so this is my nickel.
Anyone with something helpful? Otherwise the 4Runner rruns great, gets 21 around town and 23/24 on the road.
Thanks -
Thanks -
Has the flywheel ever been really checked out to make sure it is round and true, has it been resurfaced? How about the pressure plate and all the other bits like the fork and throwout bearing?
I had an old 64 Chevy pickup years ago that kept blowing apart clutches and it wound up it had the wrong bellhousing on it so the throwout bearings I would buy were always too long. Having a 350 with a few too many ponies didn't help much either
Somethings got to be wrong with the flywheel. Maybe its warped. Maybe somehow your crankshaft bent. That would cause the rear main seal to leak though.
A stock clutch should last 7-10 years unless you are towing heavy loads a lot.
You didn't say anything about how the clutches held out on your previous cars! I'm assuming this is the first time you've had so many problems
I agree with jx94148. It sounds like something else is wrong. I had my clutch replaced for the first time at 120K. I think the service shop has been treating the symptoms instead of the problem.
I would have to agree that there is something else that is not correct here. I still have the orginal clutch on my 95 p/u with 114k on the clock, and I am the second owner of the truck.
Eric
Eric
According to the Toyota service manager the pressure plate has been both resurfaced and replaced. Again according to Toyota all the shafts and bearings have been checked for alingnment. I think there is a problem with the presure plate because when I let out the clutch in 3rd or 4th there is a shudder as the system mates up.
I've had no problems with previous cars/trucks (86 4Runner before this one) with clutches lasting well into the 150K mile range - I just do not abuse my rides.
Ok check this out. Downey Off-Road offers a Super Clutch II. Comes with everything, Clutch, Pressure Plate, 10 lbs heavier Fly Wheel, Throw-Out Bearing, Pilot Bearing, and a Alignment Tool. The best package for a nice price of $440 delivered if I remember correctly. The Clutch is HD. Centerforce could not even come close to the package deal!
As far as the problems with the clutches, I would have the tranny seriously looked at very hard and with a microscope. But that is just my .02 cents!!!!! Hopefully this will help!
It's a stretch, but also have them really scope out the tranny, bellhousing and everything to make sure they are all the right parts to begin with. It is certainly possible that your truck fell during a production change and has maybe a '96 tranny on a '95 setup?? Like I said, it's a stretch
Your problem is definately odd. I have 147k and am just now thinking about changing out the stock cluctch on my '94. Not due to chatter - but it slips on steep inclines occasionally. Does the heavier flywheel really help? Seems like it would make accerleration harder but I'm only guessing.
However, after that point it is a hindrance as it presents a lot of rotating weight to overcome. It's definitely not a hot rodding option
06-01-2021 01:51 PM
tpd143
07-07-2015 09:06 AM
Steezy96yota
07-06-2015 10:00 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
