2nd Gen Articulation
Originally Posted by mt_goat
You will need to realign after doing any type of lift.
Originally Posted by mastacox
I'm aware of that, but it seems like a spacer for the upper ball joint will be especially bad for camber, are there pictures of one of these installed?
Are you concerned that the camber cannot be adjusted? So far as I'm aware all 60+ pair out there have been successfully aligned.
Frank
Originally Posted by elripster
I can post some tonight. There's been some healthy threads on these, if you search on them there are quite a few pics already up.
Frank
Frank
#26
Has anyone looked into the spring rates on 2WD torsion bars vs 4WD torsion bars? Is there any difference? What about 2WD pickups with a 4 cyl engine. They've got to be softer...
#27
Originally Posted by 914runner
hey mastacox, what is the part number for your shocks?
Thanks
Thanks
#28
Originally Posted by golden
How do you like the ride quality of the RSX shock?
#29
2WD Lenght - 1979-1983 is 35.250, 1984-1997 is 35.125", T100 is 34.75"
4WD Lenght - Pre 1993 T-100 is 35.87", 1993-1997 T100 and 1986-1997 4Runner/Pick-up is 41.874"
Fun Facts: Toyota Landcruiser has 2 sizes 45.731" and 47.62". A Nissan Pathfinder 4WD 1987-1997 has a lenght of 48.437".
The Longest is the Mitsubishi 4WD & Pick Up/Dodge & Raider both 1990-1995 lenghts are 53.812", and the Mitsubishi 4WD,Montero/Dodge & Raider 1990-1994 both 1990-1994 has a lenght of 53.800".
Now how hard would it be to adapt one of these sets of Totsion bars to a Toyota. Sway-A-Way's where 25-27.5mm in diameter... (all info from SAW)
#31
I looked into this years ago. The 4cylinder 4wd pickups have the smallest diameter torsion bars. All 4runners run the same bars regardless of engine size and it is the same as a V6 pickup. So, there is potential gain if you get the 4 cylinder pickup t-bars and put them in a V6 truck or better yet V6 4runner.
Frank
Frank
charlie_fong
09-27-2015 10:06 PM
Toys4parts
09-26-2015 01:56 PM
runnermedic
13
09-21-2015 05:20 PM
reallynotamechanic
09-11-2015 11:52 AM
