2nd gen 4runner swaybar links
hey guys, im installing a 4" superlift and need to disconnect the anti swaybar links from the swaybars but im having quite a bit of trouble because the bolt which is 17mm just keeps turning when torque is applied, this occurs on both sides of the 4runner, thanks for any replies
There is a small hex key hole in the center to keep the bolt still.
Properly executed, you hold the key and stand on the wrench to break it free. A box end wrench around the bolt and then the key in the middle should do the trick.
ok, thanx a lot and im gonna let one of them sit over night with some penatrating oil because its pretty bound up but the other one came right off after the advise
06-01-2021 01:51 PM
Steezy96yota
07-06-2015 10:00 AM
