2G guys with digi cameras (and time)
Check the cables on the top of your intake man. Also, those two hoses coming from the steering are vacuum hoses and they should be hooked up. I'm not too sure if that would affect the idling though. Does it sound like all the cylinders are getting spark? What all have you done? Is it timed right? Is the distributor Top Dead Center?
Well, I have not messed with the timing. The engine was pulled directly from another vehicle and I put it in this one after pulling the old one out. I did use the old distributor cover, but that's it, I didn't mess with the timing. However, I have not checked it either. Yes, all cylinders are hitting fine. I have driven it about 15 miles thus far. I just have to drive with both feet to keep it running (it's an auto) whenever I come to stopsigns and such. That will get old fast though. The power-steering pump is pretty much shot, so that's not much of an issue... I'll have to buy another one of those.
You may want to start by checking the distributor. If it's not on perfect it will one: cause your truck to idle crapy two: cause it to not even start. How many miles were on this engine? Do you know how to check if the engine is top dead center without removing any covers? If not e-mail me and I'll tell you. But start there. If that doesn't work we'll dig into it a little more. GOOD LUCK!
#25
Hmmm.... Make sure it's getting proper air flow too. My truck did the same thing for a bit. Also try this Start the truck, open the hood (You may need someone to keep it alive while you do this) and adjust the throttle cable. It may not be set right. Start by slowly pulling it with your fingers until it runs at just under 1000 RPM If this works just adjust the bolts.
#26
The hissing and no idle on the engine would indicate a vacum leak.
Check again to make sure all hoses are hooked up and no vacum ports are open.
You can use some carb cleaner to check for leaks (idle will go up when sprayed).
#27
