29x10.50 super swampers
Old 01-17-2007 | 01:49 PM
Ironmike4x4's Avatar
YES I've searched for both the size and super swampers and did not get my results. My question: Is there any forseeable problems with rubbings on the upper ball joint or control arms running 29x10.50 Interco Super Swamper tires on my '98 4Runner with no lift? I've fit BFG ATs with the same width and was VERY close to rubbing on the upper arm. I know the width will fit, but I am unsure about the knobs from the tires themselves. I am going with a smaller tire simply because I will need new tires in the future and the swampers were an extremely killer deal with less than 2k miles on them and all 4 tires for only $200 so I went and got them. Any experience with this size tires on your 3rd gen 4Runners? TIA.
Old 01-18-2007 | 05:12 PM
bump?
Old 01-18-2007 | 06:54 PM
jjrgr21's Avatar
you can run 31/10.50's, with a little trimming 32's
Old 01-18-2007 | 08:07 PM
AK's Avatar
AK
you will be fine. i dont have mud tires on my 4runner but on my old tacoma I ran 31x10.5x15 MTRs without an issue. I know swampers are a bit more agressive but you shouldnt have a problem.
Old 01-19-2007 | 04:38 PM
I'm more worried about the side treads or knobs, I know they will fit but am unsure of the knobs from the swampers will rub or not on the control arm.
Old 01-19-2007 | 05:36 PM
HarrisonP's Avatar
You already have them? If so why not go get one mounted and make sure it will work.
Old 01-22-2007 | 12:25 AM
TX-BLKRUNNER's Avatar
you should be fine unless they are the stuckbirds, those have some huge side lugs. even at that you should be fine
1uzRunner
63
11-10-2018 04:58 PM
punks_is_4x4
02-26-2016 05:29 PM
JookUpVandetti
09-30-2015 09:58 AM
93RedKrawler
09-29-2015 03:50 PM
nerofiend
09-22-2015 08:17 AM
