22re No Fire at Coil
I have a 22re that is not getting any fire at the coil. It will turn over all day long but will not fire...I have checked all fuses with a multimeter and they were all good. It just will not fire. Any ideas???
![dunno](https://www.yotatech.com/forums/images/smilies/dunno.gif)
Have you checked the main fuses under the hood? If yes, have you used a multimeter on the wiring going into the coil? Not sure which wire as I do not have the book in front of me. If you have power to the coil, most likely you have a bad coil.
