22re low RPM problems
ive searched the board and haveint really found what im looking for so its time to ask....anybody have misfiring problems with the 22re at low rpm when accelerating? mine will jump and studder a little till its starts to get some engine speed..makes for poor fuel economy cuz you have to hold the gears longer....only does it under load (revs fine with no problems) and after it warms up...right at start up till the time it gets to operating temp its ok....then goes bad...ive played with fuel grades and timming but donenst seem to do much...anybody experence this?
thanks for the help all
Kevin
Kevin
the plugs, wires, cap and rotor have less then 6k on them so i dont think thats the problem...ill check for anything loose or outta spec
Originally Posted by quik05
try changing the fuel filter,same thing happened to my buddy, clogged fuel filter, but sounds like spark plugs to me.
"Post up again telling us what it was that fixed it!"
Why does no-one ever write the resolution to their problem? I am having the same problem on a 22ret. Thank you all.
steve miller
10-10-2015 01:40 AM
