22RE Idle problem
22RE Idle problem
I have a 1990 22RE its having idle problems I think its this valve on the bottom of the intake plenum. Has anyone else had this problem know what this part is called or maybe have a part #.
It surges at idle and sometimes caues it to idle high making shifting a pain because it revs up when you push the clutch in. Someone told me its this part under the intake plenum at the front just behind the throtle bodie but was not sure what it was called auxillery air control valve maybe.
Is this the valve you're referring to?
This is the AS (Air Suction) Reed Valve. Btw, my truck is an 89 (22RE), and my intake is of the straight style. I believe the angled throat on the throttle body was on the earlier models.
I would first check the throttle, make sure it is closing fully and not sticking partly open when you let off the gas. Then see if the dashpot is sticking or slow to let the throttle close, it is the spring loaded plunger under the throttle that acts like a shock absorber. If it's vent line or filter is clogged, it can close too slow and cause the problems you describe. If that is OK, check the TPS idle sense contact:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Make sure that the TPS is working and adjusted properly. Then see if you can properly adjust the idle speed, if it is too high, you can get into the ECU's fuel cut RPM (around 1200) which kicks in if idle speed exceeds that and/or if you hit the brakes at idle. IN those case the idle will cycle up and down and the ECU first cuts fuel then restores it to the engine.
Ok I'm on glue I looked today in the light its on the bottom of the throttle bodie and does have some hoses going to it. Its either the Air flow meter or air valve I'm not sure. Thanks for the info 4Crawler you got me pointed in the right dirrection. Anyone know if its one of these if its rebuildable?
steve miller
10-10-2015 02:40 AM
Jnkml
07-06-2015 02:20 PM
