22RE Guy's What * of timming do you use?
Hey guys just wanted to get a base line of what everyones set up is. At what * of timming do you have your motor set for and what octain gas are you running on with the timming set point? Just curious. I have mine set for 5* running 87 Octain. I had pinging problems and retarded the timming, I just did a complete tune up, plugs, wires, cap, rotor, and thought I might be able to get better results by advancing it again.
Great question!
I've been having the pinging problem, too, on my 93 4x4 with 68k miles.
I tried all the standard stuff to stop pinging: make sure it's running cool enough, cooler heat range plugs, checked knock sensor, distributor, etc.
This weekend I decided to pull my entire intake, clean my fuel injectors by hand, and check the intake valves. I cleaned some partially-clogged injectors (which can cause a leaner condition on that cylinder = PING), and also soaked and cleaned the backs of the intake valves with GM Top Engine Cleaner. Cranked it up yesterday with about 80% of the ping gone!! After driving it 40 miles this morning and blowing out more of the intake valve crap I loosened yesterday, I could hardly even hear a single ping, going uphill in 5th gear, on cheap gas, with the pedal to the floor.
To answer your question, I'm at stock 5 deg BTDC timing, but I want to get 2-3 more degrees before I'm happy :-) Combustion chamber deposits are probably the remaining culprits.
Otherwise runs like new (actually better).
Hope this helps.
Hope this helps.
