2004 5spd shifting
if I'm driving aggressively i shift at 5000, if you go much over that the engine will flatten out and slightly after that the rev limiter will keep you under 5800, if I'm driving normal i will shift at 3600-4000, the header and exhaust system really opened up the top end, so a stock truck's shift points may be lower, if i punch it in 1st around 2500, it will blaze the 33's, wet of course, and i can usually keep them spinning through 2nd and scratch in third
punks_is_4x4
02-26-2016 05:29 PM
kbpickens
10-02-2015 04:37 PM
