2004 4runner transmission fluid questions
Hello. I have a 2004 4runner V-6 4x4 and decided to change the oil for the first time. Well, ive only had manual transmission tacomas and pickups in the past and never a auto tranny. So i went underneath and found what appeared to me to be a drain plug for the oil and proceeded to unscrew it. Well, as you can imagine, transmission fluid came out, not oil. Ooops. Wrong drain. The fluid was still very hot so i couldnt stick the plug back in and just let it drain out. Anyhow, on to my question. Approx. 4 quarts came out. I read the manual to see what kind of tranny fluid to stick back in and it said Toyota type IV fluid and 2.0 US quarts. Is this a typo??? I drained at least 4-4.2 quarts out of the tranny. So the dealership was closed and i went to the auto parts store and was recommended Valvoline MaxLife ATF DEXRONŽ III/MERCONŽ auto tranny fluid. So i bought 4 quarts and filled her up. Does anyone know the correct amount of fluid for this engine? Is the type of fluid i used ok? The manual makes it sound that if you didnt use the Toyota type IV fluid, the transmission would melt down or something. Thanks!!!
Oh crap. So do you think its okay to drive for a couple of days until its flushed? Is 4 quarts enough fluid? The manual states 2 quarts. I read somewhere this is a typo however. Thanks!
TURBOrunnerNM
07-22-2015 12:01 PM
