2003 Tacoma 3.4 quad cab 4wd.
Recently changed the ignition coil as check engine light was on. Code was P0304. Cylinder 4 misfire I believe. After ignition coil change, I reset the ECM by pulling the EFI fuse. Drove it a few miles and the CEL started flashing??? Also, the ABS light would flash on when I first started it, I believe that was caused by the headlight that is out?? Any suggestions?
88yotasr5runner
10-09-2018 11:16 AM
SO/TX
22
07-13-2011 11:21 AM
afonda
01-14-2008 07:44 AM
