2002 Toyota 4Runner 4X4 making loud bang when shifting into Drive or Reverse
So as mentioned in the title, anytime I shift from park to drive or drive to reverse I get this loud banging or clanking noise from under the car. I assumed this was bad U-joints. However, I put a video camera under the car to record the joints as I shifted into and out of gears but the joints did not have any play in them.
I have been searching this forum like crazy and I have come across people with the same symptoms that ended up having a bad rear pinion bearing.
I am also getting a vibration from 65 MPH and higher. Could these all be signs of a bad rear pinion?
It's either your rear diff due to loss of pinion preload (happened to me before) or your transmission's got a problem.
You can check your pinion preload by getting under your car, removing the driveshaft and trying to move the pinion yoke up/down/left/right. If it's loose in any direction and/or has very little drag, it's your pinion. This will probably mean you'll have to get your diff rebuilt.
I do show in the receipts that they did order a bearing but after calling the Toyota dealership and giving them the P/N it was not a pinion bearing.
Can I not just replace the bearing causing the vibration?
I will check this preload and see if that could be the issue.
Thanks for the advice.
Problem has been solved.
The noise was not coming from the back as I was almost sure of, it was a bad torque converter. I tore the rear end apart and couldn't find any bad bearings or even any sign of problems. Preload on the pinion bearing was good, lash was set fine and I found no signs of premature wear. Along with this banging sound I was getting a vibration around 65 MPH and up. Just wanted to add a reply to let anyone know searching out this problem what these symptoms may imply.
