2002 Rotor size
2002 Rotor size
I have a 2002 4Runner SR5 ( not the limited) , I have 16 in tires....I need to replace the rotors and when I go online and specify this Mod it recommends 15" rotor's.( I bought this used, did this vehicle come with 15" tires and the 16"s are optional ? ) , If I saw I am a 2002 limited owener it recommends 16" rotors. Please advise, what Rotor size should I order and any recommendation on after market rotors
You can check the rotor size by removing the tire then measure the circumference with a flexible measuring tape. Then use D = circumference/3.1416.
Another way is to get the radius and multiply it by two.
Still another way is check out the user's manual.
Re aftermarket rotors, go for DBA Slotted rotors. IMO, they're the best. check out http://www.dba.com.au
HTH.
justdifferentials
Just Differentials
08-30-2015 09:42 PM
justdifferentials
Just Differentials
08-15-2015 06:25 PM
