2002 4Runner RS3200 Keyless Entry
Old 02-01-2008 | 10:21 PM
element's Avatar
I was whining in another thread about the interior lights not coming on when you unlock the doors with the keyless entry system on a 2002 4Runner (no alarm) when CLin9383 mentioned his 96 with an RS3000 did light up. I have been researching the alarm option for the 2002 but seem to be a little confused.
The keyless entry is standard on a 2002 4Runner (according to J.A.’s 2002 Specification PDF). The RS3200 and RS3200+ were dealer or port options. Do either of these alarms use the remote (fob) below?
The remote has a panic button on the back.
Also, which do you have (RS3200 or RS3200+) and do the interior lights come on when you disarm or arm the alarm?
Old 02-02-2008 | 07:34 AM
ninjarunner's Avatar
I believe that you can set that with a scan tool to make the lights go on or not.
Old 02-02-2008 | 08:18 AM
element's Avatar
That is interesting. A friend was surprised when I told him that I didn’t think that was possible. He said that was how they did it on his wife’s new Jeep but I couldn’t find anything in the 2002 manuals to indicate you could do it that way.
My searching last night seems to indicate that the 3200 was for 2000-2002 trucks without the factory keyless entry and the 3200+ was for the same model years with keyless entry. If the 2002 came with KE standard, I assume that all of the 02’s that had an alarm used the 3200+.
Can anyone shed more light on this?
Old 02-02-2008 | 12:18 PM
skjos's Avatar
I installed the 3200+ in my 2002, but there is no programming options to turn on the interior lights. I've attached a link that shows the programming options.
http://www.customtacos.com/tech/file...rogramming.pdf
Old 02-02-2008 | 12:29 PM
skjos's Avatar
The 2002 4runners came standard with keyless entry:
http://www.top4runners.com/ja/runhist/2002_4runner.pdf
If the dealer installed the alarm it should be the rs3200+, if the alarm was installed at the factory, it may be something else.
If the alarm was factory installed, you would have a dash light like the one shown on page 13 of your owners manual.
Old 02-02-2008 | 10:09 PM
element's Avatar
Thanks for the info Skjos. I have also heard back from a couple of PMs that confirm your statement that the dealer alarm does not add this feature. The last thing I’m trying to check is if there is a setting that can be changed in the illumination control module that can be changed with a scan tool.
Right now it looks like the lighted ring around the ignition is the extent of the “illuminated entry” system.
Old 02-03-2008 | 09:33 PM
element's Avatar
Sorry, duplicate post.
Old 02-04-2008 | 09:00 AM
paddlenbike's Avatar
Some 4Runners have "dome light supervision" and some do not. I found my alarm module and confirmed I have the RS3200+, and the interior lights do not come on until you open the door. (Mine is a 2000 SR5 with the keyless entry/alarm.) My neighbor has either a '99 or '00 SR5 and his 4Runner has dome light supervision with the factory alarm.
I would really like to figure this one out too...
BeMiceElf
10-10-2015 10:40 PM
Road Bull
10-10-2015 05:55 PM
rushw
07-18-2015 02:46 PM
Seattle_Sign_Guy
07-12-2015 01:38 PM
Poncho0206
07-10-2015 07:21 PM
