2001 Tacoma disable FWD?
I need to use the L4 mode of my manual transmission, but with the front wheel drive disinaged. It looks like all the control is done within the front differential case. Any way to override this function to get basically an L2 mode?
Thanks
Thanks
Your answer is right here: http://www.marlincrawler.com/htm/tra...twin_stick.htm
Originally Posted by youngbuck
You have 3 options, 2 of them have been suggested the third is adding a dual T-case assembly from Marlin....
The twin stick requires you to take the transfer case apart, to remove the shifter rail lockout pin.....
Manual hubs require you to replace both front CV's and hub assemblies, usually you'll need to finda a donor vehicle and just buy the complete spindle assemblies, cost is around $500
Dual cases requires the most work.....but gives you much more gear options......
LCE_Performance
10-01-2015 01:03 PM
bryan34w
12
09-30-2015 02:50 PM
charlie_fong
09-27-2015 10:06 PM
