2000 Tacoma 3.4l Rear end Grinding Noise
Old 01-30-2015 | 11:57 AM
TacoThunder2000's Avatar
So my tacoma is a 5 speed 3.4l v6, when i start from a dead stop and accelerate quick, there is a bad grinding noise coming from what seems like the rear diff. also i do not know if these two are related, but when i am in neutral, slowing down from 20 MPH, there is a light click/knock about every few seconds. just one little click. i know that i need to replace my rear u joint, could this cause any of these issues?
Old 01-30-2015 | 12:10 PM
millball's Avatar
If you know that a u-joint is bad, why don't you replace it before it damages the driveshaft, and then you will know if your noises remain, or not.
Old 01-30-2015 | 12:13 PM
JasonYota's Avatar
X2 or before you lose your driveshaft on the interstate.
Old 02-01-2015 | 10:02 PM
maachine's Avatar
replace the u joint and see whats up after that. i had weird squeaking/ grinding sound from my truck one time. i got under it and greased every zirc fitting i could find and it went away. it turned out the slip yoke on the drive shaft was dry.
Old 02-05-2015 | 10:28 PM
rogerg0834's Avatar
Diff fluid
Make sure that your differential has fluid. If its leaking then the grinding noise might be the gears due to low fluid. Also, check your rear tires underneath, the inside, for differential fluid splatter on the tire. I had to redo the bearings on mine due to this problem.
06-01-2021 02:51 PM
icentropy
07-11-2015 08:21 AM
Avenged
07-09-2015 08:55 AM
Jnkml
07-06-2015 02:20 PM
