Last edit by: IB Advertising
- Toyota 4Runner 1996-2002: General Information and Recommended Maintenance Schedule
Important information to help you understand your 4Runner.
2000 4runner - maintenance schedule
Hi all,
I have a 2000 4Runner, 5spd SR5, which I bought in 2004 with approx. 70XXX miles. I remember taking the truck to Toyota for "servicing" right after I bought it. I have no idea what they actually did with the car. Ever since, I've been pretty good with changing the oil/oil filter, but I haven't done anything else.
This summer I was thinking of checking/replacing certain things in the car so I come to you guys for advice.
Some of the things that come to mind are:
timing belt
spark plugs
spark plug cables
serpentine belt/s
water pump
coolant fluid
fuel pump
tranny oil
differential oil
My car now has about 85XXX miles on it. Please let me know if I should replace/inspect any of the items mentioned above. Is there anything else I should be looking at???
Also, please point me to any write-up that covers this subject. I'm currently searching for any info relating to this.
tia,
maguirre
timing belt
spark plugs
spark plug cables
serpentine belt/s
water pump
coolant fluid
fuel pump
tranny oil
differential oil
tia,
maguirre
fuel filter
new PCV valve
clean/inspect mass airflow sensor
clean throttle body
clean/inspect battery terminals
rear/front differential oil
transfer case oil
transmission change
seafoam
grease drive line
new PCV valve
clean throttle body
transfer case oil
transmission change
seafoam
grease drive line
Did you mean fuel filter or fuel pump? I have done pretyy much everything listed on my 01 with 81xxx miles except the fuel pump. For some reason I thought it was in the fuel tank and a real pain to get to. I would add = change power steering fluid.
yeah,... I meant fuel filter... sorry.
so you guys are saying I should take care of everything I listed plus what Cosmophonic12 added???
thanks,
maguirre
thanks,
maguirre
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
