2000 4runner limited, fog lights don't work!
Old 01-09-2011 | 10:30 AM
michalik_piotr's Avatar
I checked the fuse and its good..... no juice at the lights. Anything (quick) to check or just going from lights back checking the wires?? Thanks!
Old 01-09-2011 | 10:43 AM
xxxtreme22r's Avatar
have you tried troubleshooting the switch? assuming there is a separate switch, I don't know if there is or not.
Old 01-09-2011 | 10:47 AM
theres a switch on the same stalk as lights, hi's and low's....everything else works fine, so no, i have not tried that yet...
Old 01-09-2011 | 03:06 PM
rideexileex's Avatar
to isolate a switch problem, manually ground the negative side of the coil on the fog light relay with a jumper. If the lights come on, it narrows it down to just that
Old 01-09-2011 | 05:01 PM
mrexcitebike's Avatar
Huh? Can you explain? I'm in the same boat, no juice to the fogs - I checked continuity on the fog relay, but i'm confused at how to check using the method you described...
Old 01-09-2011 | 05:07 PM
vital22re's Avatar
totally a bro
Staff
toyota uses switched grounds to run the lights. No ground to the relay no power.
Old 01-09-2011 | 09:35 PM
Well, got mine figured out. Lose/broken wire causing a short and blowing the fuese.
ACZR
06-23-2015 08:55 PM
Schif
06-20-2015 09:39 PM
ShaunKris
06-17-2015 05:33 PM
95Runner
7
06-08-2002 02:02 AM
MRael
15
06-05-2002 03:20 PM
