2000 4runner with frame patches
Old 11-25-2015 | 07:12 AM
87turboPA's Avatar
Went and looked at a 2000 4runner. It turned out to be a sport edition with the rear locker. The seller had no idea. Truck was clean for a PA truck some rust underneath not to bad. Then I saw the frame patch. The patch ran about 24 inches on the inner frame rail passenger side to the rear suspension arm. Just the side of the frame was patched. I could not see the other side because of the gas tank. It looks like a decent weld but my gut tells me to stay way. Im just looking for opinions here. What do yall think stay away? Truck has 150,000 and was well taken care of. I could probably get it for around $4,000
Old 11-26-2015 | 02:20 AM
wyoming9's Avatar
Red face
It is a 15 year old PA vehicle.
How do the brake and fuel lines look??
I am sure it will need more work .
I am sure you could find the same thing south of I 10 for about $8,000.00
If you don`t want to buy it If it is not gone already it will be soon.
For the price you quoted it would be titled in my name already!!!
Old 11-26-2015 | 03:51 AM
dropzone's Avatar
Fossilized
not sure but i believe there was a frame recall on 2000'ish 4Runners
too bad the rust has already set in on the frame repair,
I would go over the rest of that truck with a fine tooth comb, but after living in NY for 6 years, a rusty frame is just something you are gonna have to deal with...
Old 11-26-2015 | 10:45 AM
wyoming9's Avatar
Red face
4Runners built in Japan it was the Tacomas having the frame recall
Still going on now with the newer trucks
Old 11-27-2015 | 06:13 AM
87turboPA's Avatar
yeah I mean everything else on the truck seems to be ok. Brake and fuel lines are good no major rust anywhere else. Although it is hard to look at the frame where the gas tank is. Yeah I wish the frame recall was on these 4runners. I would pick this thing up and go get a new frame. I got a project in the garage already maybe I will just be patient until I find a cleaner truck. Thanks for the input
Old 11-27-2015 | 02:36 PM
wyoming9's Avatar
Red face
It comes down to the person reaching for the money so if the inner voice says pass listen.
I failed to listen to mine I am still paying for that mistake 20 plus years later
Old 11-27-2015 | 03:28 PM
87turboPA's Avatar
yeah I have made that mistakes many times guess i will go with the gut on this one
Old 11-28-2015 | 03:14 AM
ThorInc's Avatar
If everything works on it and it has been well maintained, it would come down to how good is your gut........ I would look at it again to be sure and offer him/her $3500 and see what happens. I just repaired my frame right where the frame and the rear LCA meet on the exhaust side and the other side was as fine as can be in Ontario, Canada. Also, the area that was reinforced looked worse than it actually was once the surface rust was grounded off. I would be more concerned with the engine, tranny or locker not engaging, etc.
Just my opinion.
I8URSVT
03-02-2021 06:23 AM
hmmhoyhoy
10-11-2015 05:54 PM
Aaronmarston
09-22-2015 09:39 PM
JookUpVandetti
09-17-2015 09:25 PM
Quick Reply: 2000 4runner with frame patches
