Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
- Toyota 4Runner 1996-2002: Brakes Diagnostics Guide
Guide to diagnose trouble and recommended solutions.
2000 4Runner Brake issues
2000 Toyota 4Runner 4x4 SR5
60K miles
Curious if anyone has had this problem with their brakes on 4Runners. The brakes feel a bit "mushy" to me, at times. I've topped off the Master Cylinder fluid, the brake pads check out okay, and from what I can tell the rotors are in good shape. I also, occassionally, get pretty bad shaking if I am braking downhill. However, when braking on an even plain or uphill there is no shaking at all. Does anyone have any idea what brake problem I am facing? If you have any suggestions please let me know, thanks!
60K miles
your rotor are probably warped or have runout. the downhill is because they heat up when constantly used. if it gets worse you should replace the rotors. as far as the mushy, you might want to bleed the system.
Yep, those are warped rotors......as more heat is generated, the shaking gets worse.
This thread should eliminate that issue for youi:
http://www.ultimateyota.com/index.ph...=26&topic=54.0
Also use a power bleeder to ensure you have no air in the system and adjust the rear drums so you don't have any excess play there either.
Adjust your rear brakes. I have to adjust mine every few thousand KM.
If you notice a lot of diving as you brake, that means your rear brakes arent doing much of the braking, therefore putting close to 100% of the brake force in the fronts.
I think the recall was for weak rotors that thumped too early in life. the fix was meatier rotors. my 1999 did this and I lived with it. sometimes really hard braking would warp them back straight, and it stayed that way until the next hard braking cycle.
I have new rotors now and they are dead perfect.
also, a stuck disc brake piston can cause thumping. they only get stuck if you go mudding and don't tear down and clean the wheel and brake assemblies afterward
Aleeex_u
06-05-2016 06:52 PM
voiddweller
19
05-02-2016 09:10 PM
