2.7 tacoma problems
Old 08-05-2008 | 09:21 PM
84 yota ex-cab's Avatar
2.7 tacoma problems
I have a 1998 tacoma 4wd 2.7 4 cyl. and it is cuting out and backfiring alot. I ran the codes and i came up with a o2 sensor. I replaced it with a new one and didnt change. I just cleared the codes tonight and now it will hardly idle. the cut out is mostly on the low end
Old 08-05-2008 | 09:30 PM
fez97T's Avatar
I had a similar issue on a 96 dodge dakota (i Know not a toyota) and it turned out that after i replaced the o2 sensor the new one got fried almost instantly after i started the truck
Old 08-07-2008 | 08:29 AM
ricky's Avatar
You replaced "it"? There's more than one O2 sensor.
Old 08-07-2008 | 08:50 AM
BigBallsMcFalls's Avatar
in any case, a bad o2 sensor won't make the thing run -that- bad. just rich
but it will get contaminated and fail from whatever else is causing the problem
test MAF first....MAF issues typically show up at idle speeds first
smthwsn357
05-01-2024 08:28 AM
94whiterunner
07-12-2015 08:15 PM
Seattle_Sign_Guy
07-12-2015 01:38 PM
Poncho0206
07-10-2015 07:21 PM
akaphilly
07-09-2015 03:18 PM
