2.7 spark plugs
Old 01-09-2019 | 08:04 PM
RedYota93's Avatar
2.7 spark plugs
Odd question, but will the spark plug from my 22re swap over to my 2.7? Just picked up a 2.7 with a miss, and I have a set of spark plugs for my 22re sitting in the shop. Thanks
Old 01-10-2019 | 09:02 AM
75w90mantraN's Avatar
Dont you have a way to check specs in your shop? That member with the magic answer might be wondering this as well.
Old 01-12-2019 | 10:11 AM
Dirt Driver's Avatar
They're the same physical size, but I think the heat ranges are different. There are plenty of cross-references online. You can also spot an ignition misfire with a timing light if the 2.7 is a distributor model.
edward watts
01-16-2018 02:41 PM
Co_94_PU
01-24-2017 11:01 PM
rams
06-13-2011 02:22 PM
mkgarrison5
18
02-07-2007 09:35 AM
